Re: Hoosier\'s , Tire Pressures & Track Temps
Hot air pressures too unreliable to be of use? That's the first time I ever heard that one. The pyrometer is a very useful tool for determining whether you have the optimum wheel alignment, particularly camber and, to a lesser degree, toe. It will also tell you if you have way too much or way too little air pressure. But, this Hoosier has a very wide sweet spot to operate within. The tire is designed to operate with an optimal shaped footprint that is acquired by adjusting to the optimal air pressure for the track conditions on any particular day. There is a balance that has to be struck between ultimate performance and ultimate wear. In an endurance race, say of 2-3 hours or more, you will likely be running pressures in the high 40's if you want the tire to last. For a single qualifying lap, you may like the mid to high 30's. For a typical 20-30 minute run session, you'll probably be somewhere in the 38-42 range. Unless you want to realign your car at the track, make ride height changes, shock adjustments, etc., hot air pressures are the most commonly used tool to tune the car to the handling preferences of the driver. Hope this helps rather than confuses the issue.
