This morning, with 600+ miles on my 2003, I made a trip to one of Viper shops here in Houston. My car is part of the valve recall, and the results showed. The first run was 378 HP and 429 torque, which are disappointing numbers and certainly lower that I would have expected, even with the valve issue. However, the second run was really weird. At 4,500 RPM, the HP was still below 250, and the dyno operator stopped the run early. These numbers were showing almost 100 HP less than the first run. The shape of the HP curve on the first run was jagged, and the second run was almost a ZIG-ZAG. The second run seems to signal a serious problem to me.
I'd bet that the guy doing the testing is one of the most experienced Viper techs in the country, and he said "I never seen a Viper do this!" He also stated that he would mention it to Charlie (the Dodge engineer I think) the next time that they talk.
I'm planning to do the recall, and I have spoken to the dealer that will be doing the work. I think parts are supposed to be available after May 26th.
What would you guys do next? What do you think?
Comments / questions / advice appreciated.
