HOW DO YOU REMOVE HOOPS - HELP
WANTED
ANYONE KNOW HOW TO REMOVE THE HOOPS OR HAVE A MANUAL SHOWING DIAGRAM OF HOW
ITS BOLTED TO THE CAR. DOES NOT SEEM VERY HARD TO DO, JUST NEED TO KNOW WHAT
DO I HAVE TO REMOVE TO GET TO THE HOOPS BOLTS. NEED TO KNOW ASAP.
THANKS TOM
Tom F&L GoR
Wappingers Falls
There's a plastic cover behind the seats, about shoulder high. Remove it, and to the immediate left and right are the bolt heads going horizontally. They are "pins" in that the threads are on the near side tube, not on the far side. Remove the two bolts and pull up.
W
WANTED
sounds pretty simple, looks like only 4 screws holding the panel. looks to me
the bottom of this panel slides under side sills panel, do i remove
them. i'm sure i'll figure it out, if you did this before is there anything i might
need to know.
thanks, tom
