How Long for break in??
Joseph Houss
NJ USA
1000 miles 'til you're free!
VERY STRICT BREAK-IN!
Do not exceed 2000-2500 rpm's for the first 200 miles
Increase by 500 rpm increments every 200 miles
Does someone have a copy of Helbig's original quote?
GTS Bruce
Orchard Park,NY,USA
Break in is 1000 miles.Light throttle for 1000 miles.Do not exceed 2500 rpm for the 1st 200 miles,3500 rpm for the next 200 miles,4000 rpm for the next 200 and 5000 rpm for the next 200 miles.ALSO,Change oil at 200 miles and 1000 miles. Bruce
C O D Y
Vancouver, WA
It's the exchange rate.....
RoyV101621
Indiana Suburbs of Chicago
Technical Service Bulletin
Group: Engine
Date: Feb 25, 2000
Subject: Replacement Engine Break-in Procedure
Models: 1992-2000 (SR) Viper Roadster/Coupe
Discussion: The following break-in procedure is suggested for any New Viper Engine.
Share this information with you customers as needed.
During the first 1000 miles (1610 km):
1. Avoid long periods of engine idling.
2. Wait until the engine has reached operating temperature before driving
enthusiastically.
3. Check the engine oil level at each fuel fill since a new engine may consume some oil
during the first few thousand miles (this is normal and not a sign of an engine problem).
4. Keep the vehicle speed below 70 mph (113 km/h).
5. Do not make any full throttle starts or full throttle accelerations.
6. Avoid driving at a constant engine rpm for long periods as follows:
. First 200 miles interval (322 km), light throttle run-ups shifting at a maximum of 2500
rpm.
. In addition, it is suggested to change the engine oil within the first 200 miles of engine
break-in.
. Second 200 miles interval (322 km), light throttle run-ups shifting at a maximum of
3500 rpm.
. Third 200 miles interval (322 km), light throttle run-ups shifting at a maximum of
4000 rpm.
. Fourth 200 miles interval (322 km), light throttle run-ups shifting at a maximum of
4500 rpm.
. Fifth 200 miles interval (322 km), light throttle run-ups shifting at a maximum of 5000
rpm.
Policy: Information Only
RoyV101621
The break in proceedure is not just for the benefit of your new Viper engine, it's also to benefit the driver with his first super-fast car. Keep the shinny side up
- know wha' I'm sayin'
