here is how you figure it out...
# injector= (crank Hp x .65)/10 injectors, then multply that number times duty cycle. The .65 is the coefficent you use for forced induction.
example: (800 Crank Hp x .65)/10= 52lbsx90% duty cycle equals 47 lb injectors so in theory for about 700 RWHp you need 47# injectors under forced induction. For naturally asperated change the coefficent to .50
also note you better make sure to use high impedience injectors with the stock computer/piggy back or you will need a special driver to use the low impedience injectors. I think Sean Rowe had the best price on the Bosch 50# injectors.
As an FYI... The lime green 42 lb/hr injectors are rated at a fuel pressure lower than what Vipers use. At Viper fuel pressure, lime green 42 lb/hr injectors flow ~50 lb/hr.
