How to determine throttle body size?
Bad_Byte
Corpus Christi Tx
Ok this question may be silly but how do I determine the throttle body size?
Does it take an inside micrometer to measure the inside diameter or is it stamped on the body or coded in a model number?
Thanks in advance for any assistance.
ewave
Dallas, Texas USA
On my 97 GTS I used a set of calipers to measure the inside diameter of the throat before the butterfly valve. It measured 60mm which I think is stock for these cars.
You can see the throat is machined to this diameter, as the machined surface looks different from the cast surface.
No members online now.
JpKL
