How to determine throttle body size?
Bad_Byte
Corpus Christi Tx
Ok this question may be silly but how do I determine the throttle body size?
Does it take an inside micrometer to measure the inside diameter or is it stamped on the body or coded in a model number?
Thanks in advance for any assistance.
ewave
Dallas, Texas USA
On my 97 GTS I used a set of calipers to measure the inside diameter of the throat before the butterfly valve. It measured 60mm which I think is stock for these cars.
You can see the throat is machined to this diameter, as the machined surface looks different from the cast surface.
Yaccob2
