How to remove and install half shafts
Glenn Sober
Columbia, Maryland
I broke the drivers side half shaft.
What is involved to remove the stock half shafts and what is involved to install new Roe Racing half shafts - please?
Nine Ball
Houston, TX
You will have to basically dismantle the suspension on that side of the car. I take loose the upper A-arms from the frame, swaybar loose both sides, shock/strut removed, alignment link disconnected. Might have enough room to then just pull it out, once all that stuff is hanging. It just pulls off of the differential, it is a slip-fit yoke on there. If it seems stuck, use a prybar to pop it loose, there is just a C-clip inside holding it onto the differential stub shaft.
G
Glenn Sober
Columbia, Maryland
I think I may have further complications. I was using a pry bar for 45 minutes and can't get the half shaft out of the differential.
Drew
Prince George BC Canada
Yeah, I swapped a gen 4 diff into my gen 3 and had an entertaining time with one side's half shaft. The passenger side pretty much popped off with a little pry with a screwdriver, but the driver side wouldn't budge. Ended up pulling most of the suspension on that side as mentioned and braced for a hard pull straight out from diff and the thing just popped right out and I almost fell over because it came loose so easy, no tools needed.
merakkw
