You can get about 750hp and tourque on pump gas. To spin 700rpm you nedd the GTs-r it has the smaller crank journals. Also the intake is not sufficiant. You need to go to an ITB setup. The early GTS-r intake had very short runners wich caused a loss of low end torque. The later ones had longer stacks to increase lower end power. The Dry sump is also required. If I remember my dry sump system was manufactrured by Daily Engineering for MOPAR. I have a GTS-r engine that I am converting over to street use right now. LAter down the road I may modify it again for forced induction.
