1.8t
So my car is to the point that it will kill a fresh battery in about 7 to 10 days if the car is not driven. The car is stored with everything turned off and the alarm NOT armed. I went and had the battery and alternator tested, and got the following diagnosis.
In researching that "trouble code" online, the most common fix was a new alternator. So I replaced the alternator, drove the car around for a week or so, and had the car retested. The car showed the exact same error and it was also showing signs of a struggle during cranking, which is another indication that it is draining the battery.
I am fed up with this crap. Does anyone have the slightest idea of what the problem could be? I am going to go through the car and check all the grounds, but I don't expect them to be an issue. Is there any weak point in the electrical system that I should target first? I have a multimeter, but I am no electrical guru. What should I be checking for?
