Add my car to the long list of cars with this problem. When my idle sticks at 1500RPM, there seems to be nothing I can do to regain normal idle speed. It just goes back down to normal when and if it wants to. I am running the stock computer program, stock throttle bodies, with the only flow changes residing with the K&N's, smooth tubes, and Corsa cat-back. It's a 2001 with 1700 miles on it, so the problem occurs early not due to worn or dirty induction parts.
The fact that the problem is "here and gone" with no seeming pattern would lead me to think it is an electrical issue. Be it the PCM or TPS's etc. A vacume leak or idle mixture issue would be constant maybe only changing under severe climate changes. I have had my very annoying & embarrassing problem occur at all air temps from 40-90F. Although I never drag the motor along when braking, I only use the brakes for stopping.
I would guess that the Gen III's probably don't have this problem as they only have one throttle body to deal with. It may very well be an isuue of trying to synchronize two throttle bodies that gives the computer such a dynamic problem to manage.
And as "Vanishing Point" pointed out. Why does the car idle lean ? What is the purpose of adding undue heat ? Maybe it needs to be done for emmission purposes... ?
I'm going to call Dan Cragin @ DC Performance this week to see if he has any advise for my year car and tuning set up.
PLEASE HELP !
Signed - All Reved Up...
