Serenity Now
This may be a stupid question but how do you install this if I get one?
Do you have to take off the actual shift linkage bolt in this pic also? If so how does that come off? I know how to get the shifter/shaft off but my understanding is you can't pull the **** off the shaft and reuse so I was thinking of getting the kit above. Anyone have a suggestion on how to lower the shifter a little without getting full short shifter kit? I plan to get short throw shifter down the road but was hoping for something easy/cheap for now...
www.viperclub.org
Removal of Shifter Gen 3
Just some info on the removal of the shifter. 1. Remove Ring 2. Lift leather Boot 3. Index(mark) shifter nut. Easier to re-install in correct alignment. 4. Loosen shifter nut. 16mm and 19mm 5. Remove Shifter and Boot Reverse for installation. Torque nut to 30 LBS or tighten matching your...
