bumblebee
just did a ROE fan control..works sweet! very simple straight foward install
was this the upgrade or the whole install? i have the original fan kit but was wondering how hard the upgrade is?
I need to get off my ass and put mine in. The upgrade...
Been settin' on the to-do shelf for a freakin' year now.
The instructions I got weren't that fantastic... what is the best spot to put the tempurature probe? picture?
I purchased my kit November of last year... would that be the new kit?
My probe is about 6 or 7 inches long, and about the diameter of a pencil...
I don't know if it's the new or old....
Uhhh, stick the probe...what are we talkin' about here??? Hope you got a nice nurse for this job!
Yeah, let me know if you can figure out a good position to stick the probe... cause other than sticking it directly in the fluid, hahaha, I don't see a spot where it can get a good reading.
I slid mine right in between the fins of the radiator right next to the upper radiator hose. It gets a good reading from there and works like a charm.
With all the sticking and probing, this thread has great potential to degenerate qucickly...
Do you have a pic of exactly where it is? does it have to be against the metal to get the reading, or is it getting a reading from the 'air' surrounding the area?
And yes... I totally agree!
although I would still appreciate some pics.
Obviously the plastic zip-tie's are not good enough to hold the probe in place on such a hot surface like the rad... what else should I use?
Just pull the airbox off, and then the fan is so right there in front of you a cave man could finish the job.
You do know how to get the airbox off right? The nut holding the fan on to the radiator should be 10mm wrench size.
Beauty! And don't be afraid to loosen more of the nuts along the top of the fan (there are 3 on top, 2 on bottom) if you need to pull it back more. It is flexible plastic.
If I remember right, I just drilled a hole a little larger than the probe in the fan shroud to get it through. Just be sure you don't drill into the radiator!!
Heres the problem with mine....
I finally got the probe in where 'Sweet Ride' put it... wasn't hard at all, just needed to know a good place. Anyways, I ran my car until I got to the tempurature I wanted it to turn on at, and then adjusted it to when I wanted it to turn off. once I did that, I turned the car off.... and within 30 seconds, it turned on again. So I lowered the adjustment so that it would turn off.... closed the hood... came on again.... lowered it again till it turned off... closed the hood once more... came on again...
etc.... it did this about 10 times... at this point, the tempurature on the gauge is below 90... which leads me to believe the fan will probably stay on now for like 10 minutes after the car is off. Is this right??
lol, let me know.
