Installed ROE fan control
LifeIsGood
Viper Lane, Arizona
I spoke with Sean (Roe) about how it works. He said that it would cycle on and off a number of times. My experience is that, depending on the temperature, the fan runs for 5-10 minutes after ignition off, then cycles off for less than a minute, then cycles on for a shorter time (less than the first time), cycles off and on for the next 30 or so minutes.
The ROE Racing website states:
Our kit automatically combats heat soak by cycling the radiator fan on as needed. A natural flow is created when the cooler water in the radiator sinks and is replaced by hot water through the upper radiator hose.
dave6666
I immediately step out of the car at the casa and turn a fan on that's always sitting there. Of course I don't have that option at the Quikie Mart, but at least at home the battery & fan use is minimized upon turning the car off.
Dave's 115VAC Roe kit...
FirecatF7
