Installing T&D Roller Rockers
SUN RA KAT
Guest
I just got a set of MOPAR Performance 1.7 T&D Roller Rockers and need advice on the best way to install them correctly. (I've already used the search feature and it only came up with a thread mostly on modifying the oil pan!)
So, what's the best way to install the T&Ds right the first time?
Thanks.
SUN RA KAT
Guest
Thanks, Michael. I take it that Crower roller rockers install pretty much the same as T&Ds allowing for the obvious differences.
Marc Lublin
Oyster Bay, NY, USA
After they are installed, make sure you use an adjustable push rod and measure for the correct length. Then order yourself a good set of push rods.
