Instructions for removing door panel...
Gerald
Near Tampa Bay
Did a search, can't find it..
Anyways, lost door rubber (the one that always comes off) on outside of car to the rear pillar where the entrance button is.. I think it fell down in there. I really don't want to start forcing anything or breaking anything. Does anyone have an instructions how to take the door panel off ( pass. side)
Gerald
jimandela
Western New York, USA
Gerald,
if i recall correctly it is held in place buy 3 screws.
thats it...
I only watched it being removed once.. sorry i dont have more info...
i would just take out the screws and proceed cautiously..
Qualitywires.com
Louisville, KY
It's easy. There's several black screws holding the panel on and then you pull slowly on the panels. The panels are held on by several screws and plastic panel fastners. Oh, check your door handle, theres one there too.
Vipermed 97.01
Tampa Fl. USA
Gerald
There are two hidden small screws on the bottom carpet area .you will also have to remove the 4 screws to remove the speaker as there is 2 screws behind the speaker attaching the panel to the door.Then remove the door handle bezel and there will be 1 large screw.last but not least there is one more small screw on the top section of the door on the inside by the door jam.Lift the panel upward as the top section sits in a lip by the window.
ViperGear
