MontrealACR2000
Is It \"normal\" to have a crack oil pan on a 2000 ACR ?
Hi guys, got a little problem over here..
I just got the car before winter.. A garage as done the oil change just before I store it for the winter.. All winter, I was having some oil dripping on my floor..
I told my self that it was because of a bad oil seal or something.. So, I went to the dodge dealer, and bought a oil seal for the plug.. Change it.. Problem still there.
So, I concluded that I was having a bigger problem then just a plug oil seal..
I just look at it carefully.. and I found out that I got a crack just beside the Oil plug bolt.. Starting from the bolt and goind up about 1/2".. Dammit..
Like that bolt as been screw to hard ? ..
Is it a common problem ?
What should I do.. Just have it fix by a welder..
buy a new one or a use one..
Or, just go for a atermarket one (Since I am there..) (Where is the best place ? )
Thanks for the advise..
Mike
Mike
