viperprowler1
Guys...need some assistance here. I can't lift the ACR from the front and back using a floor jack like I used to with non-ACR Vipers in the past due to the extensive aero pans under the car so I have just been raising one side at a time and putting jack stands under it while working on tires, wheels, etc. My question is, can I lift one side, place it on jack stands and "Safely" go to the other side, raise it and put jack stands on that side without the first set of jacks tipping or sliding or otherwise moving in such a way to be dangerous to me or the car, etc.? I want the car to sit on the suspension and not the frame so that the suspension is always at ride height and not with the suspension "hanging". Then I can remove all the tires/wheels and store them in the cellar, etc. I'm talking about winter storage here. I'm confident there are many of you out there that have already faced this situation and solved it so I don't have to "reinvent the wheel". Thanks in advance for your help and suggestions. Mike
