Getting A Gen 3/4/5 Viper Up In The Air With A Jack And Jack Stands
If you have a lift, disregard what you see below.
For those of us with more archaic tools at our disposal, this post is for you.
So how do you get a Viper up in the air so you can actually get some work done on it? There are many ways to skin this cat - this is mine. The tools I list here are what I recommend. Most of them are not cheap, but when it comes to safety equipment (and a jack and jack stands are some of the most important), cheap stuff doesn't cut it in my garage.
Jack: AC Hydraulics DK13HLQ
Jack Stands: Esco 10498 and 10499 (you'll see the reason for the different sizes in the next post)
Other: Race Ramps Flatstoppers
I listed two different Esco jack stands above because I use both - 4 of the 10498s, and 2 of the 10499s. Basically, the 10499s are the baby stands - this is a game where 1-2 inches matters (I tell my wife the same thing), so the ~2" shorter height does help for one very specific part of my method (again, this will be explained in my next post).
Two pics showing the differences:
There's a rear jack point accessible through the belly pan, shown below (that’s a Gen 5 ACR – the Gen 3 & 4 cars don’t have that much underbody aero with which to contend):
The frame looks a little flimsy there, but it is plenty beefy enough to handle half the weight of the car. Seriously…it is
very well braced.
There are a few different ways to get a jack on it. Some folks use a hockey puck. I fashioned one out of what was originally a Protech 1006 side lift jack pad - it looks a bit ghetto (the cuts were made with a hack saw), but it did work.
Ew.
That was before Doug Shelby developed a more elegant solution, which has been on my car for a while now:
Highly recommended.
Here are the main jack points you can use - they are made from pieces of angle welded to the frame, and are easily seen when you look under the car:
And secondary points that you can use when the need arises:
If you are going to use the rear jack point in the center of the car, you will need to get it up in the air at least 11-13 inches depending on what jack stands you are using. That doesn't sound like a lot, but with a lowered car, you will end up driving the bottom of the front bumper into the ground unless the front is raised some.
That's why I use the Flatstoppers. You can most certainly find some other product or way to do this (like a 2 x 12 or two), but I already had the Flatstoppers on hand.
I used to be able to just drive the car onto them, but ever since I switched to lower profile 295/30-18 front tires (and lowered the car so it didn't look goofy), I can no longer do that without breaking off the little flaps that sit in front of the tires up there. Because of that, I have to jack the car up from each side to be able to slide the Flatstoppers under the tires. My car is actually low enough that I have to jack the car from the side using the rear jack points because the front points sit too low to get even my jack under there.
Steps 1-2: Get the Flatstoppers under the front tires to get the nose up a bit - if you can drive the car on, that's the easiest.
Step 3: Jack the car up by the center rear jack point so you can get jack stands under the rear main jack points. Once the stands are under there, you can lower the car down onto the stands, which has the added benefit of bringing the nose of the car up in the air just a bit.
Step 4: Jack the car up by one of the front main jack points so you can get jack stands on the exposed part of the frame close to the engine. The frame is stiff enough that the car will be pretty level side-to-side even though you are grabbing it on a corner.
For Step 4, the front stands can go here:
Lots of meat where the front of the frame is reinforced to place a jack stand or two.
Step 5: Repeat Steps 3-4 until you get the car as high as you want it. I only move the jack stands up one notch at a time - the last thing you want to do is get greedy and have the car slip off the stands.
It'll look something like this:
That's high enough to be able to pull the transmission in case you were wondering (you probably weren't though).
Step 6: Move the jack stands outboard to the front main jack points by jacking the car from the frame around the engine. This step is optional, but it helps to get the stands out of the way when trying to do things like changing the engine oil.
Now might be a good time for a beer - getting the car up in the air always stresses me out, and you are about to see why.
