<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jcaspar1:
Actually you can read the code yourself by cycling the ignition key On-Off-On-Off-On-Off within 5 seconds. The check engine light will flash a two digit code. Example: 7 flashes,pause, two flashes is code 72 which is catalyst efficiency below required level. Let us know which code/codes it throws and we can let you know what it is. Or you can get a shop manual which has all the codes. Good luck
<HR></BLOCKQUOTE>
Hi Jeff. Actually, you cannot. After 1997 Vipers, the onboard diagnostics are no longer available. Too bad. It was very handy. 1998's + have to go to dealer, or you can order the Ease PC Based Scan Tool from Sean Roe, and do it yourself.
Chuck G.
