Just installed New 285 fronts.. Still get minor shaking at certain speeds.
Gerald
Near Tampa Bay
I just installed Mich 285-17's Sports on my 98 GTS. With my old tires (worn to wear strips) at about 87 mph the wheels would shake a little (feel it throgh the steering wheel). I didn't worry about it because I thought it would stop with these new tires. Nope, it still does it at the exact same speed. They used a computer balancing machine, etc.
Any ideas? Could it be the rears? Rims?
Gerald
Marv S
Scottsdale, AZ
No,Excessive wheel run out can cause the car to shake
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Gerald:
Wheel Run Out, would that be an alignment issue?
Gerald
<HR></BLOCKQUOTE>
Martin D
Dunwoody, GA USA
Hey man -
Take the car and have them high speed balance the tires. Should be about 20 bucks per tire. Should fell like driving on glass after that.
Regards,
DEVILDOG
VCA Member North TX
VENOMVILLE, TEXAS, USA
Gerald,
Hope you didn't twist the frame from all that boosted HP!
Just kidding! Seriously, hope you get the problem identified and fixed. I would have the alignment checked first since you have the same situation before and after new balanced tires. Good luck!
unclgreggy
Southeast, NY
Gerald,
whoever suggested getting them high speed balanced may be right on. I often had the same problem on my TT supra and my brother on his mercedes. Sometimes when I was lazy, and didn't want to travel to the shop that I knew had a high speed balancer, I left it to a regular balancer - big mistake. there is a difference. On my viper I travel to a DISTANT place to have tires mounted and balanced. Also, check the rears as suggested. Also, could one of the rims be bent? Check all these things. Do you have another set of rims you could try? perhaps another viper owner has a set you could use just to test it?
good luck.
Ron
Indianapolis
<FONT face="Comic Sans MS">I've used this system for all of my new tires purchaser and swear by it. Exactly like when the car was new..... Zero vibration at any speed.
To elaborate a bit, from the Hunter Wheel Balancing web site:
What Causes Excessive Wheel Vibration?
Wheels Out of Balance
Static wheel balance measures only "up and down."
Static wheel balancing uses a single weight plane and only addresses "up-and-down" imbalance. This is simply not adequate for today's vibration sensitive vehicles.
Dynamic wheel balancing uses two weight planes. This eliminates "up-and-down" and "side-to-side" imbalance. Dynamic, two plane wheel balance should always be requested, even on custom wheels when hidden weights are required.
Dynamic wheel balance also measures from "side to side."
Wheel Force Variation
An out of round tire (runout) causes wheel vibration.
A stiff spot hitting the pavement causes vibration.
A perfectly balanced tire can still vibrate due to Force Variation.
Wheel Force Variation is most frequently due to wheel runout or uneven tread or sidewall stiffness in the tire. Runout is when a tire or rim is out of round when rolling; frequent causes are a bent rim or uneven tire wear.
Uneven tread or sidewall stiffness can be found in new or worn tires. Tires by design are never uniformly flexible throughout nor are they perfectly round. And no two tires are exactly alike in these characteristics.
How Wheel Force Variation is Corrected
OEM Match Mounting matches a high point or stiff spot on a tire with the low spot on the rim, for maximum roundness.
1. Match mounting a tire and rim by matching the high point or stiff spot in the tire with the lowest spot in the rim, can make the wheel "round when rolling."
2. In some cases a wheel is so out of round it should be replaced.
3. In some cases a tire with excessive Force Variation is defective.
Tire Pressure and Wheel Alignment
Improper tire pressure and/or misalignment causes irregular tire wear which creates and amplifies imbalance, resulting in wheel vibration. Alignment can be adjusted and wheels serviced to reduce or stop the vibration. Ask your technician.
Steering and Suspension Components
Steering and suspension components need periodic inspection. They can eventually wear out resulting in wheel vibration. Excessive wheel vibration from other causes can also shorten steering and suspension component life.
Other Hidden Causes of Wheel Vibration
Wheel to axle mounting error
Brake component wear or failure
Drive train or engine component wear or failure
Vehicle component characteristics
</FONT f>
Kurt 97 GTS
Dallas, TX
Gerald,
I would have them check the rears!! I had a similar issue with my 94 RT and thought it was the fronts. Turned out to be the left rear!!.....Kurt
Jay Lopez
Dallas, TX USA
I had a similar problem. I would get a vibration with either my street tires, or my slicks on different wheels. I finally narrowed it down to my brake calipers. I had vibration in one of the calipers because the piston had honed out the hole a little bit. The piston was vibrating in the hole, and it caused the brake pad to chatter around causing uneven wear. I had the caliper rebuilt and the vibration was gone. Hope this helps!
sham5430
