K&N finally released an air filter for the Gen 4.....
rcl4668
Oregon, USA
This is the response I got from K&N:
"Dear Rich,
Thanks for contacting K&N. Unfortunately at this time there not a dyno plot available for this product, however we have performed extensive testing on this filter to guarantee that it will not cause the check engine light to come on.
Please let me know if you have any other questions.
George Hsieh
Tech Support
K&N Engineering
[email protected]"
/Rich
Viperless
MN
"Dear Rich,
George Hsieh
Tech Support
K&N Engineering
[email protected]"
/Rich
Extensive testing but no dyno?? Hmmm....
CitySnake
Manhattan, USA
Just for the record (and because EVERYONE is so desperately interested :rolleyes::rolaugh:) my ass cheeks are far more sweet than sensitive.
Now go run with that .... (or not). ;)
But we still don't have any definitive dyno testing results?
F
FikseGTS
South Florida, USA
"It's worth some minor gains.... I've done before and after dynos with the stock filter vs no filter (12HP), and stock filter vs the RX-8 K&N filter (7-8HP).... gains were across the powerband..."
seabass
Iowa
wouldn't it make sense to have the wind turbulence going thru the hood scoop/air filter in order to closely resemble the real world conditions of driving at WOT? Not sure which way the bias would be if the k&n vs. no filter vs. green vs. rx-7 filter were done on a static dyno...
make any sense?
J&R3xV10
Las Vegas
I have used K&N in all of my vehicles and yes you can "feel" the difference. Its not like adding NOS but there is a small but noticable difference in the engine and exhaust tone as well as the engine rev when going from a poor OEM filter to a high performance filter. In the case of my Viper truck or my Ford diesel Excursion it was a HUGE difference and very noticable but the gains were also higher then 7 hp I don't remember the numbers but I think it was >15hp.
I contacted K&N within a day or two after getting my 08 in January 08. I offered my car as a mule but they said they were not ready to begin development for the product yet.
albinonile
florida
funny that they would no cel, but have no dyno numbers. Bet it decreased or stayed the same.
Blue Batmobile
San Diego, California
KnN will be using my car for fitment testing on their new intake sytem for O8/09 Vipers :). They will be doing dyno testing as well. Will keep you guys posted.
Bat
ViperGeorge
Greenwood Village, CO
What the SRT engineers say
I was randomly looking through other threads today and came across a posting by the SRT engineers. Lord knows where I found it but maybe one of you that is better at this stuff may be able to find it. The engineers were responding to some questions (I think from Canada members) about dyno results on 08/09 Vipers. Apparently the cars were losing power at 4000 RPMs as the Air/Fuel changed went rich - 10.3 to 1 or so.
SRT engineers explained this can/will happen if you change to a non-production air filter. It messes with the Mass Air calibration. The engineers said they spent a hell of a lot of time and money developing the production filter and they said save youe $50 bucks and stick with the stock filter. They said they use way more expensive equipment than the $50K dynos that most places have. They also said if a different air filter would give 10 or more HP don't you think they would have installed it to begin with.
If I can find the thread again I'll post the link.
ViperGeorge
Here's the post I was referring to in my last post.
http://forums.viperclub.org/grail-trail/625903-why-venom-control-runing-10-4-afr.html
Quote:
Originally Posted by Schulmann
We had a dyno session day in our club last Saturday. One of the thing that stunned us was the really rich AFR on the GEN4 Vipers above 4000rpm. For some unknown reason the AFR drops from 13 to 10.4 suddenly at 4000rpm causing the engine to loose 50hp. We were expecting 540rwhp and got 490 rwhp.
It makes me remember my old 2000 when the AFR suddenly dropped due to ignition issues above 5000rpm.
We had two Vipers with this problem. On the third one the dyno master has stopped the session because the engine was hesitating too much at 4000rpm.
What is going on in the GEN4 VENON control at 4000rpm ?
How Venom control protects the engine against knocking ?
FROM THE SRT ENGINEERS:
We'll help Herb out with this one - We don't want to get into the habit of responding to any and all issues on this Forum but we will make a few comments on this issue.
First, the addition of an aftermarket air filter element can and generally does adversely effect the operation of the MAF sensors. Any change to how the air enters the clean air duct upstream of the MAF sensors can change the airflow measurement. A change in the construction of the filter element will change its characteristics. In any of our testing, the production air filter element has almost no restriction at production airflow (we worked ******* this!) so save your money and prevent other issues by not changing the filter element.
There is a WOT timer in the Venom that protects the exhaust valves and pistons from over temperature. The timer is set to enable at 4000 rpm and after 12 seconds of uninterrupted WOT the timer matures and the fuel is enriched by 6%. This is not something most owners will ever experience while driving the car but it is something that can happen on a dyno. Any time the driver tips out of WOT, the timer is re-set.
The knock system will add fuel as it reduces spark in order to protect against over temperatures. When running on dynos in some cases we have seen noise induced by the dyno that can be interpreted by the system as knock. This will greatly reduce the performance.
Make sure you are running good fuel on the dyno and keep air and fluid temperatures under control - not something many shops handle very well. The Venom will retard spark and again add fuel for inlet air and coolant temperatures that are above normal. This is done to prevent knock and protect parts.
In summary, it's not quite a simple as it may seem to get a "proper" run on a dyno. Chrysler spends many millions of dollars on equipment to properly test cars and engines. If we could do it for the price of a $50,000 or $100,000 dyno and get good and consistent results we would! If simply changing the air filter element would get us 5 or 10 HP, we would have done it!
seabass
Iowa
One other question??? I just tried to install the Green Filter I bought and found out that it is too tall to get the filter compartment closed back down... anyone successfully install a green filter on an 09?
Thanks!
SilveRT8
Boucherville, Quebec, Canada
Re: What the SRT engineers say
That was my car on the Dyno, possibly on a bad batch of gas.
I went back 2 weeks later on good 94 oct gas and got 545 rwhp this time
rcl4668
Oregon, USA
Bat
Bat -- whooohoo that is great news; any idea when they will start work and dothey have an ETA on completion? Thanks for being the mule.
/Rich
Puntacanaviper
