Key Fob Reprograming?
98viperGTS
South Carolina
I am trying to reprogram some key fobs on a 97 Viper. I have done this with a 96 RT/10 and for the most part all I had to do was ground the green wire. However with the 97 the green wire has some sort of female plug at the end, so I thought if I stick a wire in it and ground the wire it would work. Well it did not. Is there some where that I should have hooked the green wire into?
Also, with the 97 GTS can I use a newer style key fob or do I have to stick with the older looking one?
Any help with this would be great.
VIPER BAZ UK
ENGLAND
On my 02 i had to get the dealer to log in and do it....
But my old Gen1 i did it myself by grounding out green wire..
Asp Man
Kelowna B.C., WEStern Canada
"Also, with the 97 GTS can I use a newer style key fob or do I have to stick with the older looking one? "
You can use the newer style fobs no problem, speaking from experience.
Ron
Indianapolis
You can use the new key fob as long as it's for a Viper.
I suspect that you're not getting good contact between the female plug and ground. Thread a small screw into the plug and use alligator clips on the screw and frame.
Go Fast For Life
Ron,
I was under the impression that grounding the green wire was only good for Gen 1 cars. Does it work on Gen 2 also?
twinturbo3150
Ron,
yes it will work for the gen II, but the green wire is located in the DLC data link connector under the dash to the far left. I took a piece of wire and actully stuck it in the pin and then grounded it when I was ready.
RAYSIR
Salem, OR
Ron,
Worked on my 98 GTS just followed the directions here in the Illutrated section by ViperMad. :laugh:
mogocar
