ViperRay
I put Tom Hayden's 40 mm rear calipers on the GTS and have run them for two track weekends now. What a huge improvement!
I have Brakeman 3's all around. After two weekends, I checked the pads figuring to replace the fronts and found that the rears also were done! I put on all 4 at the same time. At no time did I lock the rears.
This setup (in conjunction with removing the rear prop. valve) definitely improves the braking balance. I can't compare it to StopTechs but, then again, this mod doesn't cost thousands!
