Snake Bitten
You could easily do the Corsa cat back, tubes and filters, fan upgrade, and oil change yourself...that would take you about a day by yourself, or less if you had some help...Can't think of a better way to spend a day...Then all you would pay for is to have the rad and brake fluid changes, and the HF cats welded in...I would take a old blanket or sleeping bag to the muffler shop when you get the cats welded up, so they have something safe to set your side sills on...It does take about an hour to flush the rad and re-fill, and don't let them forget the two block drains...
