Last 300 side exhaust
Bad Brad
Question, does anyone know or where to find the range of Vin #s for the 1995 RT/10 Vipers that were the
"Last 300 side Exhaust " that way it would confirm the stamp is original to the car and correct.
thanks Bad Brad in Fl.
GRANGER73
Not sure the VINs were sequential. The MDH number would probably be more reliable.
ViperJeff
Legacy Member
Idaho
I would have to check and see if that info is in my data. Or I reading it wrong based on Grangers73's response.
If in deed you just looking for the last 300 Vipers built in 1995MY, the only way to do that is with the MDH (VIN's are all over the place at times). I haven't finish the MDH's for 1995MY and it's not a fast process.
If you have the vin, PM me the last eight and I can look to see what I have. I also have a viewable list of 1995 Vipers here: http://www.vipertruckregistry.com/Viper Lists/1995 Vipers.html that uses the last 4, however, I'm not sure you will find what your looking for on that page.
Jeff
GermanViper
Munich, Germany
Jeff
Mine is the 554 in your list and a "Last 300"-version.
Bjoern
B
Bad Brad
Viper Jeff, Last eight Vin# 95 RT/10 SV201411 trying to confirm LAST 300 Exhaust is stamped on my car , I did find it.
So what exactly does that do for the car in value. Mine is original not modified, great condition, 23,675 miles. the only
thing I am changing are the wheels. Last owner ( I am the third owner ) put 5 spoke 96 wheels on it. I bought some 3 spoke 95 wheels having
them powder coated and put on so car is totally correct.
Then selling the 96 wheels in the next few weeks. write me at [email protected] easier than this site. thanks Brad
ViperJeff
Legacy Member
Idaho
The bad part is I have nothing in the data I have that identifies this. The only thing I was able to find was... Individuals on the line at the Mack Avenue plant pin stamped the last 300 Gen 1 vipers produced near the passenger side window pillar on the foot box with "Last 300 side exhaust". If I was to just look at the 1995MY Viper and not take in consideration the MDH ( I don't remember ever seeing a 1996 with side exhaust), that would equate into the VIN range or: SV201285 thru SV201584.
I hope someone can give you an idea of value, it's just not something I do. In 95, there were more Black Vipers built than the Green, Yellow and Red. So that might hurt rarity, but probably not value I do like that you're taking it back to original
Jeff
B
Bad Brad
Thanks Jeff, for your quick, and honest response, anyone need 2nd Generation wheels??
Brad in FL
aelimos
