Little Help From the Wiring Experts - Rear Tail/Side Lights & RearView Mirror
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
Thanks in advance for the help. Getting close to the final touches on my 2009 Vert to Coupe rear end project and need to tie the coupe rear side markers into the rear tail lights. The Vert wiring works fine for the Coupe rear tail lights, but I need a wire to tie into for the side marker lights which the Vert does not have. Should be easy to tie into one of the tail lights - just need to know which one (of the 3) and which wire.
Also - I picked up a homelink mirror which has maplights - which needs a switched power source (which I assume I would grab from the existing mirror wiring, a continuous power source, and a ground. Does the existing mirror wiring have this or do I need to run a wire up to it. May also use this to hardwire my V1 or Passport.
Thanks again.
Rocket
PS - since I believe that all posts should include a picture - here is my hood with custom driver stripe.
Wiretech
Toronto Ont
The side marker lights can tie into the tail lights,not sure what colour but can be checked with a test light, as for the rear view mirror wiring there is a B+ and ground but there no switched ignition , the BCM has it but wouldn't touch there if your not sure, the easiest ACC switched is the radio power.
ViperGear
