I think the low tire sensor is set to go off much lower than 30 I run 24 in the rear tires and it will go off on very cold days, as the pressure drops a little below 24, but soon as the tires warm up it goes off and stays off. By the way, I think 30 in the rear is way to much for good traction, and you will not have abnormal wear or poor handling. These tires are very forgiving on lowered pressure, plus the sheer volume of the rear tire will allow you to run this pressure. When I had my 02 GTS I had the Smart Tire System on it, and I ran 23-24 in the rear, and I was able to monitor the tempature in the tire, and even after running on a 50 mile highway trip on a 100 degree day the temp only went up a few degree's above actual outside temp, and my front tires that had 30 in then showed about the same temp, and the temp in the tire is a very good indicator if you were to low. There was no handling difference in the car at the lowered pressure, but it did have much, much better traction, and as an added bonus, the car road a bit better. I guess if you were cruising at a sustained high speed 90 mph or more for a long time it may be ok to run 30 or more but not for sporting around. I also keep an eye on tread wear, using the tool the tire shops use to check depth.
Skip White
