Lo tire light
srcsrt10
I just got my car out today for the first time since fall. Went for a short ride and noticed the "Lo Tire" light on. Came home and properly inflated to 29psi, turned ignition on again and light is still lit. I never had this problem before and was since I installed a new battery if it had to reset or something. Any help would be greatly appreciated
PaViper
If it does not go out after driving it, you will most likely have to take it to a dealer to be re-calibrated....happened to mine last year as well
dragon rider
Just had the low tire warning come on today. Rt. rear was just below 20 psi. Filled tire back to 30 psi, turned the car back on and let it run for a few minutes and the light reset itself.
Racer Robbie
Guilford, CT-USA
Just disconnect the battery wire at the fuse box under the hood for a minute and then reconnect it. then unlock your car door with the key and turn the key on to the on position only. Do not start the engine. When everything settles down and resets then turn off the key and start your viper. You should be all set.
ViperGear
