OK, according to the Body Diagnostics Manual, it is in the dash between the speedo guage and the oil temp guage. They don't describe the location but only have a picture. According to the picture, there is a sticker on the front of the module. The sticker is sideways from top to bottom writing with a Chrysler pentastar in the top right corner. On the bottom right corner it has SAE then in a box [ABS], after a bunch of numbers. It also has an FCC ID# on it, so that should be the only thing in the dash with an FCC #
Looks like you'll have to take off the black plastic cover that runs around all the guages to see it.
Hope this helps
If I had a scanner I'd scan it
