Looking for 2002 Water pump
There are at least 3 options out there. RyanLS, Havik and Mike 99RT&GTS. You will need to provide your unit for rebuilding or core exchange. They are pricey, but they have responded to the call.
EGarza1971
Texas
Hi, took my good running 02 RT/10 to dealer to change oil and flush radiator, for upkeep, got it back then it overheated. Now supposedly water pump leaking and needs thermostat. Do you sell pumps, do core charges, etc? Just sitting outside the lot. Thoughts? Thanks
No new pumps available. It is possible that the plastic impeller has failed. If that's all that happened, Flow Kooler sells machined billet impellers to press on. If the seal is leaking, you'll either have to rob the guts out of a Gen1 pump and swap them in, or source a rebuilt pump from Old School, or Havik Perf.
