Looking for a mopar computer
GTS-R 001
California (north)
heatandair,
Do not use a mopar ecu with Roe SC TOOOOO MUCh spark advance!!! I know, I had one and got rid of it after SC install.
Steve
GTS-R 001
California (north)
SMC,
For Sean to do that he would need to have a Mopar ecu and then tune and play for hours. The only advantage a mopar ecu would have would be the O2 sensor heat up issue which can be solved with 20 minutes and a dremel tool and an 1/8" drill bit.
I would rather sean spend his time tuning his 8 psi pulley setup!
Viper-Housecall
