looking for ALOT more power for 400 bucks?
viperama
Bern, Switzerland
Dont mind to see any gain on a naturally aspirated Car.
On Cars with 14-25psi of boost it is good.
Be carefull of injecting to much of this mixture in your engine... with to much, you will have the same problem as a car with damaged cylinderhead gasket... it will wash out your cylinders (oil film!) which is not really healthy.
Casey
Valparaiso, IN.
I think there are already some BOOSTED Vipers running around with a similiar setup.
I think 50rwhp is pretty easy with it w/boost.
Joel
Ireland
Water injection works great, but mainly on blown engines and mainly as a detonation suppressant. If you arn't near or beyond the point of detonation, the gains will be negligible. Due to the fact that injection only happens near full throttle or beyond a certain boost level, the duration of injection and quantity of water is relatively low and undamaging. Idealy the amount of water injected will be about one tenth of the fuel volume.
FE 065
MI
If you could reduce a n/a engine's tendency to detonate, you could advance the timing for more HP.
