gen2lover
I have a 2000 Steel Gray RT.I have 50,000 km on it.Both my power windows are going.I am not sure if I need a new Switch.Is there a motor too? plmk. thanks! Kevin in Ontario,Canada.![drive :drive: :drive:](/vca/styles/default/xenforo/smilies/drive.gif)
Its amazing I never see Gen 1 guys with window problemsBut hey for you guys who want all the technological advances like...windows...I hope you enjoy your Vette...I mean Gen 2
Kevin,I have a 2000 Steel Gray RT.I have 50,000 km on it.Both my power windows are going.I am not sure if I need a new Switch.Is there a motor too? plmk. thanks! Kevin in Ontario,Canada.![]()
What's the matter with them? Are they slowing down or moving at all? If there are slowing down, the lube in there dries up and you need to open up the door and lube them before you take out a $495 motor & regulator!!
Oh wizard say it's not so. As of two weeks ago my drivers side won't go up anymore but you can hear the motor running. I did a search and saw some posts saying it is probably the string end that broke and I might be able to repair it. Please don't tell me I need to buy the whole unit.open up the door and lube them before you take out a $495 motor & regulator!!
What type of lube should be used? I think I need to get lubed![]()
Oh wizard say it's not so. As of two weeks ago my drivers side won't go up anymore but you can hear the motor running. I did a search and saw some posts saying it is probably the string end that broke and I might be able to repair it. Please don't tell me I need to buy the whole unit.![]()
