Hey Everyone, Im new to the Viper and picked myself up a 2002 GTS. Ive been going through it fixing the car and have been trying to get the clutch pedal to work to my liking. I have all new clutch fluid and noticed there is some slop in how the clutch pedal linkage is held in place. There are 2 tabs riveted to the pedal arm and they hold the pedal against an aluminum plate with a groove machined into it. The brake pedal is the same however the tabs on the clutch are loose enough that there is 1/8 play between the tabs and the aluminum plate.
My question is, can I take that play out and eliminate the 3/4-1" slop at the pedal? Is it possible to bend the tabs down and make them tighter or is another method better? Or should I leave it alone.
