Lost Power?? Viper Why??? You Guy's Didn't Help [******]! Thanx
HARDVIPER
Temecula Ca.
Lost Power?? Viper Why??? You Guy\'s Didn\'t Help [******]! Thanx
#400239 - 04/29/04 03:34 PM Edit Reply Quote Quick Reply
I have a 2001 RT/10 Viper, I put a set of Ballanger Headers a Corsa Exhaust with High Flow Cats, Smooth Tubes and K&N Filters. When I left the place I had everything installed I could floor it and it would start to burn em off up to about 30 mph. Now a Month later no more sliding at all? Why the sudden loss of power? Can you Help.
STUGOTS
NY/CT
Re: Lost Power?? Viper Why??? You Guy\'s Didn\'t Help [******]! Thanx
i told u check the fuel filter and vacume element in the air box,check the plugs.
How do you know if we helped or not if you diden't do them
motor602
Silver Spring, MD
did you take into account the warmer weather and that you may actually be hooking up the back tires now????
STUGOTS
NY/CT
thats true too, tires grip better when its warmer
Motor City Mad Man
Las Vegas, NV
Who is this clown. Only a few posts on this board and he looks like one impatient, ungrateful son of a @#$& already. Help yourself over to the dealer and let them figure it out if you can't. Gheez. Maybe it's the sugar someone poured in your gas tank for acting liek such an ***.
1TONY1
Dalton Ga. (Chatt. Tn.)
I looked back at all your posts and didn't see where you asked for help ?? Enlighten me ?
STUGOTS
NY/CT
he made his post and i tried to help em and like 10 minutes later he says no one helped em without even trying what we suggested.
Qualitywires.com
Louisville, KY
if you don't want thos Ballenger headers, let me know.
Gerald
Near Tampa Bay
I really doubt your going to get any help now. Might want to register under a different screen name and try again.
2BADD 4U
N.E. Pennsylvania
I really doubt your going to get any help now. Might want to register under a different screen name and try again. :2tu: :2tu: :2tu: lolololoo
slaughterj
The fuel filter and spark plugs suggestions sound good to me - cheap, "easy" solutions that are maintenance items anyway. Also, I go from getting some wheel hop in the winter to gripping in warmer temperatures - maybe your results are the same?
sbkim
Bloomingdale, IL
this may be a shot in the dark but can you use VEC1 or 2 to fine tune our vipers to lean or richen fuel mixtures to adjust for the mods?
STUGOTS
NY/CT
The fuel filter and spark plugs suggestions sound good to me.
wow you actually agreed with one of my suggestions!!!!
thanks
Atom
