lowering , will it hurt 1/4 mile times ?
twinvipers
Raleigh,NC
Want to lower my car slightly. What options do I have and will it hurt my 1/4 mile times because of less weight transfer ?
opnwide
austin tx usa
I heard the eibachs are pretty bad for 1/4 mile. I cut my coils hoping to get better 60' results than others. I haven't had time to get to the track yet. 2 coils off front, 1 coil off back. Dropped my car 1.5" Scrapes on EVERYTHING, but very cool.
I'd like to do the same for my '95, but the 19" VR1s will rub BIGTIME and maybe even crack the fender if I hit a big enough bump. The VR1s with 345s stick out 1/8"
ACELLR8
Harrisburg, PA
I also think that Snake Oyl, has the lowering spring caps or something that are supposed to lower a half inch or so. Just another route to investigate if you wanted to lower and not go a whole inch.
Ed
RedEnuf93
Lancaster, PA
Looking at from other angle:
I cannot see how you could BENEFIT from lowering the car.
Therefore your gain is zero, status quo or even adding a tenth or so.
If your aim is at 1/4 mile, I would not do it.
I did it on mine, looks great, but I'm a poser....
PhilC
Jackson, NJ, USA
Which car are you thinking about doing it to? The ACR you can change any amount without buying anything. I did 1/2" 3/4" and 1 ". It's now back to a little lower than stock. It looked best at an inch but the scraping will get on your nerves. I think 3/4 inch were best results on the track (that wasn't necessarily due to ride height more than experience at that point and conditions).
Anthony - 98 GTS
Houston, Texas
Ed
Lowering caps or perches are made by Northwest Engineering. They lower the car 1/2".
SW
Austin, TX.
Lowered 2.25 front, 2" rear. Best 60ft, 1.39, consistant 1.42-1.44's. I got these springs from one of the Oreca race teams four years ago. I have eibachs on my silver '98 and don't like them, too stiff..
SW
jp
Umea, Sweden.
The Eibach are progressive and will not hur your 60foot. I'm using them and do regular hit 1.45 60 footers.
