MCS Coilovers Gen3-5
ogio855
Alberta
MCS 2 way remote coilovers, originally from Woodhouse motorsports.
Front Springs 550, rear 900, includes the helper springs and spacers.
Used for 4000 miles total (2 seasons) and 4 track days.
Notable difference in performance over the OE setup on a TA Gen5.
$4500 shipped & insured anywhere in North America, will be sent in original box.
O
ogio855
Alberta
They are 2 way, I was never smart enough to figure out the 3/4 way setups.
Mk97
Fort Worth
Where were the canisters mounted in the rear? In the original location I don’t see how you can get to the adjuster. Thanks
Steve M
Dayton, OH
There are a couple ways to go about it:
O
ogio855
Alberta
I actually had them mounted to the plastic structure that was underneath the trim panel directly to the sides of where they are in the above photo. The trim pulls away easily if you stick you hand in the wide parts of the trunk and you can easily adjust, and they are also hidden. I'll look around and see if I had any photos of it, I'm bad for taking pictures...
Sorry no photos from the rear, but literally in the exact spot as the photo directly above but behind that carpet trim. It was also a TA car so it has a slightly different panel design in the front section of the trunk.
