Measurements for painted stripes?
VIPR GTS
xenia ohio usa
The stripes on my 2001 are 8 inches wide, 4 1/2 inches between the stripes. The are consistent front to rear. You will love them on your car, much more aggressive looking.
USAF BAD ASP
Vetper bliss...
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by HSSSTOY:
..Avoid stripes in Lic.Plate area.
<HR></BLOCKQUOTE>
I disagree. Stripes thru the lic plate area give it a much more fluid and complete look. Mine looks great thru the plate area. Just my .02
HSSSTOY
Ontario Canada
..My thoughts if you are sticking to originality,only 96 GTS stripes run through the Lic. Plate area. Having said that I agree with you it is more visually appealing when there is no break in the stripes.
Ron
Indianapolis
<FONT face="Comic Sans MS">To be even more historically accurate, (if you choose the 1996 style stripe in the rear plate depression):
1996 GTS stripes are slightly different in width and gap between. A search will find the exact measurements or if you can't find it I can check my GTS.</FONT f>
Ron
Indianapolis
<FONT face="Comic Sans MS">Speaking for 1996 GTS's, the stripe width is exactly 8 1/4". Gap between is exactly 3 15/16".
Can't help on 1997+....</FONT f>
Kurt 97 GTS
Dallas, TX
My 97 GTS is in the shop getting strips painted on as we speak (or write).
Exact deminsions are 96: 209mm-100mm-209mm with 97 up (changed again in 2000 or 2001 I think): 203mm-112mm-203mm
Hope this helps. Also, what do you guys think about not painting through the NACA duct? Thanks.....Kurt
Ratical2
San Jose, CA
Paint thru the NACA duct. It looks finished that way...not like you dropped the duct in when you were done....my 2cents
John21
