Mobil1 or Mopar ?
Neil - UK
ENGLAND
Oil change coming up whats the best filter ?
I've got both OE Mopar and the Mobil1 filter
N
Neil - UK
ENGLAND
made a Sneaky, remove the blind from the window in the 'closed' position
and lay it out on a table, use low tack masking tape to hold the slats in place while you apply the Sneaky in the usual way, then across trim each slat with a scapel and finally remove the application tape (that covers the decal) and the masking tape
twinturbo3150
I use Mobil 1 & K&n, K&n is nice dut to the nut on the bottom of the filter.
ubnbit
Chattanooga, TN USA
I was told by a viper tech to use mopar filter and mobil oil. Something about the way it filters is better than the mobil one.
Puntacanaviper
