MOMO Steering Wheel
V10 MOJO
Youngstown, Ohio
got it this morning, millenium version, looks great...in the box, LOL
I cannot get the factory wheel off?? I have; batt disconnected, airbag removed, main lug nut removed? yet, i cant pull the steering wheel off. what am i missing here?? (other than a few more cups of coffee and a few brain cells)
anyone who has donr this "simple" task before, please chime in, im sittin here without a steering wheel on this car, LOL
V
V10 MOJO
Youngstown, Ohio
ya know, sitting here looking at this bucket...doi need a steering wheel puller??? DOH. im off to auto zone
Vipermed 97.01
Tampa Fl. USA
Rich
I can take most any steering wheel off without a puller.When D.C put our steering wheels on they did not mean them to come off,so unless you have no reguard for your old wheel,get a puller,Also pull the air bag controller fuse,before you start
Quantico, VA
Re: MOMO Steering Wheel
What Vipermed said. I just swapped my wheel and I tried to get it off without, but it was very obvious I was wasting my time. PepBoys saved the day for $9.99 or thereabouts. :)
V
V10 MOJO
Youngstown, Ohio
Scott,
got wheel off no problem, then i removed the plastic housing around the column, now i cant figure out how to remove the middle plastic piece (its light blue) that has the airbag and the horn wiring going into it. without it off, the new wheel wont fit down on far enought to start threadding itself. the horn is a simple disconnect but the wiring for the airbag is direct. should i cut it?
V
V10 MOJO
Youngstown, Ohio
i think this thing is called a clock spring? it is a black piece, labels in red writing, and blue center. front wires conncet to stock wheel, rear wiring..thats the problem
Vipermed 97.01
Tampa Fl. USA
DO NOT CUT....Rich to pull the "clockspring unit" off, at it @1:00 that there is a black release tab that you must pull up and then @ 7:00 is a plug that you must remove.You will also have to feed the 2 pin clockspring plug up through the column.It has a plastic tap about 4" up the plug on the oposite end of the clockspring(blk and blue unit)
V
V10 MOJO
Youngstown, Ohio
got it, thnx for the help. dislocated an elbow and bruised two ribs but its done. gotta be a damnn horse jockey to work on this car or a yoga master, unfortunately im neither.
Shelby3
liu;g
How bout some pictures of the final installation....
V
V10 MOJO
Youngstown, Ohio
i took a few pics but as usual i cant figure out how to post, so...if anyone wants to post em for me, let me know and ill email them
BTW, couldnt get the horn to hook up so the only flaw in my momo set up; i got to hang out the window and yell, LOL otherwise im glad i did the swap, it looks great, especially with the MGW brushed pieces and when i put in the black carbon fiber dash its gonna be sweet
ViperGear
