Moton mounting question
PJJP
TX
Since I got my Paxton installed, I need to move my moton canisters that are under the hood. I have them clamped to the cross brace that goes under the throttle body. I have seen some pics where some guys put them on the sides of the radiator facing forward. I would be interested in seeing pics of the the install. How did you attach to the wall? What hardware did you use? Thanks in advance.
MikeR
ILLSMOQ and I did some testing, we were getting different pressures based on heat from engine. As much as I loved popping the hood and seeing the cannisters, it looked cool and was easy to adjust, but wasnt best option. He ended up mounting hi and mine in the fog light area, so just remove the littel cover and you can pull them out to adjust nitrogen if neeed. They are ziptied to fender liner and not going anywhere. Plus now they stay alot cooler. Just a thought.
sham5430
