indeed, the gearing, or lack of torque down low to pull through the long first gear is really holding the car back for 1/4 mile performance...
It is not only that. it is a combination of things that will make the car lose to a more efficient smaller motor sports car. A 6000-6400 rpm power band is unnatural and unacceptable for today in my opinion unless SRT don't plan on being up top with the big dogs. That is the reason that I keep on saying/asking for over two years on this VCA that a whole new engine should be in this car designed from the ground up with smaller cubic inch, more compression and with DOHC for spinning/power potential (where the engine is at the most when we are racing). Pushrods are not gonna cut it anymore even for the corvette (they had to boost the ZR1) and when you have a massive cylinder head with 4 valves per cylinder and 4 cams is just an extraordinary advantage over a cam in block engine with those two little valves and that little silly combustion chamber and 1 cam haha...
The biggest problem to me is the engine/trans combo chosen for this new car. Not having the option for a 6-8 automatic DCT nowdays is putting this viper behind big time. Every time the viper driver has to press on that clutch trying to show that he can shift fast, the guy beside on the GTR, lambo, Ferrari or even a 28k dollar moded automatic mustang GT(like mine) is going to pull ahead and gain momentum over the standard tranny and end up winning the race. it is that simple!
On top of that you can't rev. the big v10 too high because is a huge/heavy engine and was not design for that because of the engine stroke. For the ones that believe you can rev the big V10 over 6500 rpm and be safe just buy a broom in advance because you will be sweeping millions of little pieces of off the road and that was your engine's rotating assembly one day. So the new viper revs low for todays standards and has a 3:55 rear gear and a manual tranny which means you will have to shift all the time and thus losing momentum and losing races like i said before.
This car is being held back not only on the quarter mile but also on top end and doesn't matter it will do 190 or whatever it does.. it is HOW LONG it takes you to get there, that is what it counts the most.
Tires and traction is an easy problem to solve as there are drag radials available in 345/30-19 and other racing tires to add traction but all the above will require a major engine transmission upgrade from SRT and while that is not done I am keeping my 2010 ACR.
