Motul - any drawbacks?
ViperJoe
Virginia
Planning on flushing and going with Motul, other than being on
on the road, and finding it available, are there any drawbacks to using it?
Suggestions, words of wisdom?
Russ M
LA, California
I have been using it for a while in the clutch/brakes with no negative affects. Didnt really notice any difference though.
Vipermed 97.01
Tampa Fl. USA
You shouldnt notice a difference,but the feeling of security knowing that when you apply your brakes under extreme conditions especially on the track they will be there.
Russ M
LA, California
Yup that is exactly why I changed to Motul.
This brings up a good point how often should I flush the Motul and put in new stuff?
jcaspar1
Sacramento, CA
Is there any advantage to using it for the clutch? Doesn't seem like a high temperature application. I just use high grade standard brake fluid for it.
Ulysses
San Diego, CA. USA
Although I have never spoken to anyone who has boiled the clutch fluid, the main advantage I see to have it in the clutch reservoir as well as the brake reservoir is that you only have to take one type of fluid for both to the track.
