Ron
<FONT face="Comic Sans MS">After much contemplation, I decided to follow the advice of many and take advantage of my rear main seal repair to put my flywheel on a diet.
It was a last minute decision and required soliciting the support of the Viper community for advice on:
Balancing
Bolt sizes
Need for flywheel bolt washers
and more...
First my thanks to the VCA members and Viper vendors & techs that sent me e-mails such as David Jenkins, Chuck Tator (aka Viper Wizard), Sean Roe and Bill Kaiser. All responded with valuable information that made the install go smoothly. Thanks also to Dan Cragin, who called me late on Friday with valuable information.
Special thanks though to Jon B @ Parts Rack, who as always spent all the time required to convince a skeptic that the AL flywheel was the way to go, plus explain in great detail every pro and con. He was dead on in every case.
The results:
Starting from a dead stop - I feared it would feel like I was starting off in 2nd, but it is no issue. It's more like 1.1st gear. Hardly noticeable.
Blipping the throttle in neutral - Much snappier. Nice
Acceleration - From a dead stop, no significant change. From a rolling start, livelier. More wheel spin, quicker. Hard to quantify, but feels good.
Deceleration - Haven't noticed a big change yet, but haven't really wound it out then let off yet. A bit stronger... perhaps.
Powershifting - Definitely not as impactful, but not something I regularly do anyway.
Low speed surging - No issue, same as stock for me.
Normal shifting - Nice, as you can quickly blip the throttle to synchronize rpm.
Neutral Gear Rattle - A bit louder, but who cares...
Idle Lope - A bit lopier, shifter wiggles a bit more. No complaints here.
The flywheel is a Fidanza unit (good people!). In conversation with them, found that SFI tests the unit to 9,000 rpm and they have been tested to destruction also. At 14,000 rpm the ring gear goes and at 22,000 rpm the disc goes. Wanna bet your engine (and stock flywheel for that matter) goes long before that?
Faceplate is 1050 steel, hardened throughout. Consumer replaceable for $75.00. Disc is 6061 billet CNC machined aluminum. Threads are rolled for strength, not cut. Weighs 17 lbs. vs 31 lbs. for the stock unit. Unit is not balanced, but since it's CNC machined is darn close. Most do not balance it or the pressure plate (I didn't either) and experience no problems or vibrations, however if time allows, the flywheel / pressure plate combo should be balanced by your local machine shop. (Thanks to Marv S for the balance instructions) I used my stock clutch and pressure plate as they were in perfect shape. I do experience a light chatter at startup, though it will go away as the clutch wears into the new plate. No vibration issues. You should purchase and use 8 hardened washers under the new (you should always use new) flywheel bolts. These bolts are lock-tite coated from the factory. The stock flywheel does not use washers. Stock pressure plate bolts work fine. Use non-permanent lock-tite on these. Torque all bolts to factory specs.
Conclusion, just as everyone has said, if you're in there, do it. It's worth it. If not, wait. You'll be in there soon enough......
</FONT f>
Balancing
Bolt sizes
and more...
The results:
</FONT f>
