My Battery is dead ! What to buy? Are Optimas worth it? and do they fit ?
viper spray
Austin, Texas , USA
Re: My Battery is dead ! What to buy? Are Optimas worth it? and do they fit
I had to put a small jack in my batt. tray and jack/bend it slowly open a little to get the Optima to fit in my 97 GTS. They weld the trays up at different heights on these cars and some do not fit without a little modding.
02ViperTodd
Lawrenceville, GA
Long thread for a battery..guess I'm just making it longer..Interstate Replacement
GTS Bruce
Orchard Park,NY,USA
Optima red.A little bending to install.no problem in 5 yrs. Bruce
Janni
Raleigh, NC, USA
If you are not tracking your car and sloshing the battery around - then the stock or a Die Hard will work just fine. The Optima is a bit better for hard g forces and helps reduce the spilling / corrosion that tends to happen back there. If you've not had a problem with the corrosionon the tray and the bolts for the rear fascia - then just get a stocker.
PatentLaw
Greensburg, Kentucky
It is funny, how time changes everything. One year, people are speaking highly of the Optimas. Now they are panned. Go with the Mopar. Easy. It fits. No problems. Keep it stock.
Carlos580
