madman
I would like to share my experience from having Corsa Track and request (honest) feedback from other Corsa owners.
My car is MY 05. First few hundreds mile I experienced heat buildup but since ~600miles the heat is gone. I assume that exhaust burnt out.
Now last week I decided to put a Corsa track on it to improve the 'music' and they said it brings some more ponnies.
Edit: I also installed K&N Air filters
I couldn't bear the noise and I already wrote about it. Interesting enough the same folks advising that the noise is not that bad before my purchase came up with 'we told you so' BS after I cried out loud here on the forum. No offense folks really none meant.
So now please be honest and tell me your experience with following:
AFTER INSTALLING CORSA TRACK I EXPERIENCED IMMEDIATELY LOSS OF POWER AND GROUND TORQUE.
The car had no torque 0-1500RPM and was 'lazy' all the way up to 3k After that I was unable to judge. The car almost stalled several time going from stop before I learned to floor it like with my old 4banger little S2000. I did not dynoed it unfortunately.
After I switched back to stock on Sunday I experienced that the car was much more lively, it got ground torque back and it was much more joy to drive it then with Corsa on it.
When I spoke to guy at Corsa he mummed that they did not test Corsa track with 05 models and that maybe DC reprogrammed the engine or so.
Since I have no heat and you folks were complaining about it so much isn't it possible that DC would change cats with 05 model so that they create less back pressure and flow higher? That would fall in line with my assumption (which may be wrong, I am no engine expert) that the ground torque requires a backpressure and since I put high flow exhaust on it with already decreased backpressure through (allegedly) new cats it would loose the backpressure to the point where engine would not have what it needs at low RPM. While with 03/04 it would use the backpressure of the (original) cats.
Please only COrsa owners and folks with the engine knowledge answer. Thanks.
