Diff back into the car
Last step is to get the differential installed back into the car and the car reassembled.
First, I lifted the differential back up into the frame, put one of the cover “arms” into the frame, then the flange up resting on the exhaust, and finally the 2nd arm into the frame. Obviously this would be a lot easier if you’ve already eliminated the crossover exhaust (my next project):
I used my floor jack to hoist the differential up into its approximate position, though biased a bit toward the driver's side. Slip the passenger side halfshaft back onto the output spline (a little grease will make it easier to remove for the next guy). Move the differential into its final position, reattach the upper bolts / nuts, and torque to 100 ft-lbs (21mm sockets).
The lower (pinion) mounts go through the differential mounting point, up into the frame, and then into what they refer to as a “flag nut”, basically a nut with a long tab integrated into it (there's an up and a down to it). That just floats loose in the frame so you’ll need to guide the bolt into that until it’s started:
Then torque those bolts to 80 ft-lbs (18mm socket).
Reinstall the clamps for the e-brake cables to get them out of the way for the next step, which is to reattach the driveshaft.
Note the difference in the new kit versus the old:
My 3/8" drive 6mm hex adapter wouldn't fit, given how tight it ends up against the driveshaft itself, so I had to make a long 6mm hex adapter out of a hex key and a 6mm socket:
That allowed me to get to the bolts (with thread lock) and torque them to 24 ft-lbs:
Now get the driver side halfshaft back on and (loosely) reinstall the upper A-arm bolts. Here's how I pre-loaded the suspension before torquing those to 75 ft-lbs.
BTW, it probably goes without saying, but all these torque settings are from the '05 factory manual -- if your car is a different year, definitely verify what your settings should be.
Finally, a couple shots of the diff back up in place, ready to go:
Last steps:
- Reinstall the bolt on the brake line retainer
- Reinstall the wheel -- torque to 90 ft-lbs
- Reinstall the belly pan -- torque to 40 ft-lbs
Done! Now I'm just waiting for a decent weather day to do the first drive. I'll let you know how it goes / sounds...
Bryan
