need a tuner in the IL. area
hirollr
il
I am looking to get a roe sc on my 2000 gts. I am mechanically inclined but I don't want to screw something up either. I have filters, smooth tubes and catbacks on it now. What other mods do you guys suggest on the car before I do the sc?
Quantico, VA
How much do you want to spend? Definitely change to a 180 T-stat....while you're in there. :) Roller rockers? HF cats should be a definite....headers as well....but then there go the $$$ :)
H
hirollr
il
I figured on spending between 10 and 15k. I just want to find someone that is as particular about my car as I am.
H
hirollr
il
I talked to Bill Sampognaro and he said that he doesn't do engine upgrades except for minor stuff. He said to get in touch with Sean Roe.
Paul Hawker
San Diego, Calif, USA
Would be worthwhile to check with SVSi. They know as much as anybody about supercharged Vipers.
They are in W. Chicago. (630) 876-1335. Ask for Ron Jr. or Sr,
Paolo Castellano
Elburn, Il, USA
Hirollr. Skip the supercharger and go twin turbo!
We just got done installing the Roe supercharger on a Gen-1 if you really want one!
We also have a bolt-on twin turbo for the Gen-2 coming out shortly.
Good luck!
TOOOFST
Barrington,il
$6700.you own it(blk)and/or +200 for polished.
$500.to install.Paolo or us.
I'd do it yourself.It's basic mechanic's sockets/wrenches and you'll be able to diagnose an insignificant problem and fix yourself or on the road.
It takes one day and comes with everything.
There isn't a better guaranteed deal out there to demolish the competition.
I do this for a hobby,you'll get only straight answers from me.I've previously fabricated and still have several 10second nitrous vipers out there.
Regards,
Scotty
www.westlakewelding.com
847.981.8966
1.877.H20.WALL
H
hirollr
il
What kind hp can I expect and should I have rr's, cat deletes and port and polish done first.
TOOOFST
Barrington,il
You must tell us how much HP you want and How fast 1/4mile you need.There are Roe S/C running 9seconds with 1000HP.
You mentioned spending up to 15K that will get you solid mid 10's with slicks,solid low 11's with stock tires.
H
hirollr
il
How does the roe compare to the novi. I don't mean to offend, just asking?
martyb
IL
Hirollr,
That Gen 1 that CPE/TOOOFST just finished was my 94. Car is going in for a final tune on monday. The torque with the Roe is unreal, even at 1500 rpm.
The quality of the install is outstanding. I would highly recommend TOOOFST and CPE. I may be adding a GTS to my garage in the future, and it will surely have a CPE TT setup!!!
martyb
TOOOFST
Barrington,il
Novi is centrifical and Roe's is Roots type(no lag power now).Want big HP reliability,years of testing,least expensive,and customer support!RR.
Centrifical S/Cer's have made more power and gone faster.More power more problems!FYI
Nocluehow
