Need Hardware or screws that hold on Head Pad with top off
ACELLR8
Harrisburg, PA
I was just curious where I could buy the hardware that holds on the RT-10 pad that goes in place when the Factory hard top is off.
I took the top off yesterday and noticed I did not have the hardware to hold the sudo roll bar pad on.
Are these just standard screws I could buy at a hardware store or is it some special kit that twists out and in by hand?
Thanks,
Ed
ruckdr
Renton, WA USA
The dealer.
OR, preferably your local hardware store. Four bolts that will screw into the bar, screw them in by hand (fingers) then slide cap down over the bolts (holes should be slotted), reach from under and tighten. I would have measured mine but they are installed,
prodiver
Apache Junction AZ
They are bolts with large washers attached to them. Stock they are a real pain in the a-- to bolt up if you have large hands. I modified my pad so that I could get my fingers in the slots to tighten them by hand. Use a razor knife and cut out the four slots a little larger and then use a felt tip pen to color the cut out area. You can't see the cut out area when it is on the car and it makes it a lot easier and quicker to install.
Estespropaint
